1 - 6 of 6 Posts
Gamera The Atomic Turtle
SOLVED!!! Thanks......HELP!! Stuck in CT - alarm lockout/cdl
Rained last night - got up 4am to get some clothes out of the car, won't unlock w/fob. Have pin, but can't get into car to try it.. Override not installed yet. Break window? Ouch. Cut Top? Ouch.
Replaced fobs batteries 3 weeks ago w/new duracells
Discussion Starter · #2 ·
So - if i check f7 &11 will i set off siren removing access panel?
Do I need to be near the car when re-synching remotes?
If I open boot to attach batt tender will my batt drain? from alarm going off? Batt was vjust replace with pc 625 for clam hinge.
Could this fix itself if car dries out?
Need link to immobilizer bypass thread - could someone post or pm me please?
got immobilizer info thanks
You probably already have this information. But, once you are inside the car and want to disable to immobilizer, unplug the immobilizer, insert jumpers in wiring harness connector.
Good luck,
Rich
Rich,
Can you be more specific or maybe point to a thread on this? I'd love to get rid of the whole thing, but failing that, at least bypass the immobilizer nightmare.
Thanks in advance,
Andy
1 - 6 of 6 Posts
