1 - 18 of 18 Posts
I have a 2zzge cylinder head with full ferrea valvetrain, oem rockers and MWR stage 3 cams. What are the recommended valve lash adjustment specs for intake and exhaust?
I contacted JCR and they told me .014” for both intake and exhaust.
Administrator
He's been building that head/ valve train combo for years so I would use his recommendations.
If you do not believe JCR, who will you believe. Like Catsailr27 said, Jim knows of which he speaks. 😁
He first said intake and exhaust .014 but then said this after I asked if this was for a 2zz.
“The stock Toyo numbers were always considered too tight . With stock rockers we run .018 . The roller can handle the .014”
Kind of confused me, I asked for clarification but no reply yet.
Administrator
I missed the oem rollers after reading Ferrea valvetrain. Glad he was able to clarify it! Recommendations have changed over the years to open up the intake from original specs in part to cam wiping theories.
Discussion Starter · #8 ·
The measurements are taken between the shim and the rocker, right? Or is it between the cam and the rocker?
Administrator
According to the manual.... Routine service clearance checks should be made between the cam and roller follower. Only if a valve or rocker arm is replaced need the clearance between individual valves and the rocker arm be measured.
But I'm missing that TSB that was referred to in one of the previous links but what I copied above makes sense.
That Toyota special tool looks like it would make for much easier adjustments. When I was a Kawasaki mechanic we had similar tool for KZ900 valve shims.
Discussion Starter · #12 ·
The head had ferrea rockers on it but those where replaced with oem rockers. That is the only thing that was done. Would the adjustment be off because of switching the rockers? Also the .018 is measured between cam an rocker or is the .018 between rocker and shim?
I’m not sure how the machine shop was doing the measurements but they said clearances where too tight. Intake was around .006 and exhaust was around .008 from what they told me
Administrator
Looks like according to what that manual stated above there could be differences even with oem ones so with the Ferreas being completely different I would say yes. I would email Jim and get his input since that is how he sets these heads up when he builds one. Here's BOE link to what comes on JCR head.
Discussion Starter · #14 ·
I already emailed him and his specs with oem rockers are .018. I just want to know the correct way to measure this. Cam lobe to rocker or rocker to shim?
Administrator
I was referring to your question of where to measure. I would check with him on where he measures at.
Administrator
Glad that you got clarification and now if any others run into the problem it will be searchable and the info out for all to see.
1 - 18 of 18 Posts
