1 - 12 of 12 Posts
· Alpaca Wrangler
Hello Everyone,
I would like to make charging devices in the car a little bit more efficient. I would like to be able to charge things up front instead of having to run a long cable or cables to the back of the cabin, where the 12V outlet is.
I can tap the wires from the 12V outlet and run them under the center console pretty easily but then the question becomes what to do. I have a few options but would appreciate some input
1) Is it safe to do as far as draw? The most that I'd be charging at the same time would be a phone, a gopro, and a Garmin GPS unit.
2) Due to availability of items, I'm currently favoring having 2 12V outlets coming out of the front of the center console (right below the door lock switch). I would then be able to use one of those "12v car to USB" modules and call it a day. I like this idea over having anything in the dash, although USB ports coming out of the blank panel on the passenger side would be nice, albeit too much of a pain in the rear.
Thanks for your help!
· Saffron Yellow is Lighter
Hello Everyone,
As long as you use the appropriately sized wire you should be fine for tapping into the rear lighter plug. I am guessing you would only be pulling only an Amp or 2.
· Absolute power does what?
You could also tap the stereo power that's already under the dash. That's what I did to power my gauges and USB outlet/charger and radar detector. I haven't had a stereo in the car for many years so I'm not powering both however.
I think it's the purple/green wire in the harness. You could either cut into it (with a vampire clip) or get a new harness and plug it in. That would negate your stereo though...
· Super Moderator
There's a spare switched circuit in the fuse block under the dash. Lots of documentation here.
For power, I had good luck mounting a USB port in the small panel to the right of the steering wheel column down inside of the trinket tray in my old Elise. A friend of mine installed a power port in the front by buying one of the switch panels for cars with driving lights and mounted the power port in the new extra light switch opening.
· Alpaca Wrangler
This might be useful for wiring up the gopro and radar detector, since they'd be mounted up on the windshield and I could run the wires down through the a-pillar.
there is a power outlet in the back?
Get a head unit with a usb charger built in like the sony dsx 310 which is what i am using
1 - 12 of 12 Posts
