1 - 5 of 5 Posts
I just bought an '05 Elise with the following history:
1) front clam was replaced just prior to buying it due to small crack
2) took it to the track yest. and battery accidentally disconnected during session - reconnected no problem
When I press the large button, doors lock.....after 5 seconds I get a continuous high-pitched beep (assuming this is the alarm)
I have already tried resyncing the fob
and I have put the interior light in the down position
any suggestions?
Forum Founder
Check the intrusion sensors, specially the front one. Is it being pressed down?
Randy, where is the front intrusion sensor located?
Randy...thanks for the tip - it IS the left front access panel that is triggering the continuous buzz...here is my dilemma
The front clam was replaced with Exige mesh so I can't take the left front access panel completely off. However, after unscrewing the outer part, I can see the sensor...after rescrewing it on tightly, it seems the access panel just doesn't press on the sensor unless I push on it...
Any suggestions...????
Forum Founder
It is adjustable.
1 - 5 of 5 Posts
