Here we'll keep a list of all the wiring/electrical components needed for this swap.
My limited understanding is you need an Engine Harness, Charge Harness, Honda ECU and an adapter harness or relay box to adapt the signals into the interior of the lotus..
Required OEM Harnesses:
02-06 RSX Charge Harness (P/N: 32111-PRB-A01)
02-04 RSX Engine Harness (P/N: 32110-PRB-A00)
OR any swap equivalent/universal harness (hybrid racing, k tuned, rywire etc)
Adapting Harnesses/Components
Rywire relay box (contact rywire for details)
Hondata Lotus Dash Converter (for use with stock lotus gauge cluster)
Innovative Wiring Kit:
CorSport: Lotus - 2005+ Lotus Elise/Exige - 50904
Not much detail known and this time., I was told you may need this AND the Relay box made by Rywire. It does appear to have the OBDII port and several other sensor connectors. Does anyone know exactly what this harness contains? Does it replace one of the OE harness?
ECU/Engine Management
Hondata Kpro (uses 2002-2004 RSX Type S/PRB ECU)
http://www.hondata.com/kpro.html
AEM EMS? does any other engine management work?
OEM Engine Sensors
Primary/Secondary 02 sensors:
OEM Part http://www.hondapartsunlimited.com/acura/rsx/36532prba01/?year=2003&trim=type-s&engine=6-speed-manual&group=electrical-exhaust-heater-fuel&subgroup=exhaust-pipe-muffler&part_name=sensor-middle-oxygen
Denso Equiv Replacement
http://www.amazon.com/Denso-234-9005-Oxygen-Sensor/dp/B000C5UFVM/ref=au_as_r?ie=UTF8&Make=Acura%7C58&Model=RSX%7C747&Year=2002%7C2002&carId=005&n=15684181&newCar=1&s=automotive&vehicleType=automotive
http://afhkparts.com/shop/uncategorized/denso-02-04-rsx-s-primary-wideband-af-sensor/
Throttle Position Sensor:
The OEM Part is part of the throttle body assy.. ref item 5
http://www.acuraoemparts.com/delray/jsp/prddisplay.jsp?inputstate=5&catcgry1=RSX&catcgry2=2002&catcgry3=3DR+TYPE-S&catcgry5=THROTTLE%2BBODY%2B%28TYPE-S%29&ListAll=All&vinsrch=no
Aftermarket option:
http://www.k-tuned.com/blog/products/k-tuned-billet-tps-sensor-v2/
IACV
Aftermarket option may require modification to tab (thanks Butters):
http://www.aipelectronics.com/index.php/new-idle-air-control-valve-motor-iac-fits-2002-2007-rsx-type-s-civic-2-0l.html?Tracker_ChannelID=28&Tracker_CustomerID=319&Tracker_variantid=617138&gclid=CPrZgdHqmbsCFeo9Qgod_WUAdw
Knock Sensor:
OEM Part for K20 Block (P/N: 30530PRBA01)
http://www.hondapartsunlimited.com/acura/rsx/30530prba01/?year=2003&trim=type-s&engine=6-speed-manual&group=engine&subgroup=cylinder-block-oil-pan&part_name=sensor-knock
OEM Part for K24 Block (P/N: 30530-PPL-A01)
OEM Engine Sensors
Aftermarket option:
IACV
Knock Sensor:
