1 - 7 of 7 Posts
I believe I have a fuse out (my turn signals no longer work). I am trying to change the fuse. however I am unable to remove the front access panel, I only see the one screw in the top let corner, can anyone please provide what I am missing in order to remove the panel?
Thanks
There are two tabs on the opposite side of the panel from the screw. Loosen the screw then pull it lightly up and away from the opposite side.
Forum Founder
It is just one screw.
Then the panel pulls away as it rotates from the center. There are two alignment posts that insert into the center clam spine.
Remove the screw and pull it toward the side of the car and it will make sense.
Lotustalk.com... faster than the Owner's Manual!
xtn
www.theapexinn.com
You have to twist them out and put a penny behind them. :D
1 - 7 of 7 Posts
