How do I reach the evaporator coils?
1259 9
I want to spray some Frigi-Fresh on the evap. coils to remove the musty smell but I have no clue what it looks like nor do I know how ot get to it. Can someone help please? thanks!
1 - 10 of 10 Posts
Remove passenger side access panel. Pull off the large hose (called trunking) that connects the climate chamber to the air distribution unit. You should be able to see the evaporator.
What he said. If you see the heater core instead, go inside and switch temp control knob to other direction to move the flap.
while your at it, get a little bit of "duct work insulation" fiber on one side, mylar on the other. wrap the trunk, mylar out... every little bit helps... drill out the blank off panel in the pedal box for even more air, and tape up the fresh air inlets behind the grill in the crash structure during hot months. - if you have A/C performance issues - these help.
thanks for the advance fellas. I took the access panel off and I see the trunking, but I'm not sure how to get it off (and more importantly get it back on). Any thoughts?
I never thought about insulating the trunking but that's a pretty good idea.
mine was was just stuffed in there...
wait - that didn't sound good at all
on my car the trunking was simply slipped on at both ends - just tug on it and it comes out...
Drat! that sounded even worse!!!
i wrapped it with insulation, leaving about 3/4" short on either end to allow room to tape off the ends. there is not a lot of room in there - so don't go crazy and wrap it thick. remember insulation works best not by density, but by fluffy space.
1 - 10 of 10 Posts
