1 - 3 of 3 Posts
I had to replace my axle CV asm. (other post) Now I can not remove the Hub/Bearing Assembly from old axle asm. I have the pin nut Out and I thought only the axle shift splines was all the holds the hub/bearing but I can t get it to move
What am I doing wrong?
New and old below. I need to get the Hub/Bearing Assembly from old to new drive cv asm
You need a medium/large sized 3 jaw puller from any auto parts store. The hub and CV come together in a near interference fit. You need to put the jaws on the flange of the hub then there is a middle bolt that you use a ratchet on that will push on the end of the CV, pushing it back
Got it.....bigger hammer worked .......hitting the large nut on shaft not on threads.
1 - 3 of 3 Posts
