Just finished a valve adjustment. Exhausts were between 0.41-0.45mm which is within the the 0.35-0.45mm spec so I didn't touch them. Intakes were between 0.07-0.14mm and the specs are 0.15-0.25mm so I adjusted them to 0.21-0.23mm. I'm wonder how the cams look because I can see some of wide lobes seem to not have any wear on them and are dark, while all the small lobes are all shiny. Or is that just because the small ones ride on the rollers?
