1 - 7 of 7 Posts
I'm trying to remove the rear clam and have arrived at the point the speaker surround needs to be removed. Unfortunately the harness bar runs right through it. I know this has to be simple, but not simple enough for me.
Addict
2007 Lotus Exige S
Remove the harness bar. There is not much room for the socket and ratchet so use a low profile one if you have it.
You don’t have to remove the harness bar. For the difficult screws I used a short Phillips head “bit” (with a hex end), but instead of putting it in a drill or socket handle, I used a small closed end wrench to turn the bit (SAE, but I forget what size). Make sense? It’s like a very short, right angled screwdriver. If you put a little tape on the hex end of the Phillips bit you can jam it into the wrench so it doesn’t fall out.
HTH, -Ed
Addict
2007 Lotus Exige S
HTH, -Ed
Maybe I miss understood but I think the OP needs to remove the whole pannel to access the bolts holding the rear clam on and not just a speaker cover. I am not sure that pannel comes out with the harness bar in place.
Edit: I see some threads saying you can remove those bolts through the speaker hole, I thouht removing the harness bar was easy enough.
It’s a bit of a blind reach, but yes you can remove those bolts through the speaker holes, that’s how I did it. Faster, but maybe not easier than removing the harness bar and rear panel.
-Ed
1 - 7 of 7 Posts
