1 - 5 of 5 Posts
My front bumper running light wire chewed by Mr. Mousy.
I have to re-attach the wire at the back of the bulb housing.
How do you take the unit out? I pulled it up and down or i played wiggling any which way but does not seem it can be removed in the front other than taking the bumper out?
Is anyone here have done taking this out? :mad:
you can't remove without removing bumper unless you destroy them, you can however push them back enough to rotate them to be able to get to the wires, I had to rewire these also. you may end up molesting the foam behind them but easily replaced, just need to replace enough of the foam behind them to keep them in place.
I almost lost mine, before you rotate it, etc. put a screw in with a wire or string attached to it. That way if you drop it inside the bumper can avoid no other choice but removing bumper....
1 - 5 of 5 Posts
