1 - 20 of 27 Posts
I have been hearing many different stories about clams being damaged by 2mph bumps and bottoming out. Just how fragile are these? How much does one cost to replace?
Would a rock from another car break the clam? Thanks for any info you have.
wow. 8-16k!!!!! How much is a front clam?
what objects have broken clams before?
Walls, other cars, animals in the road, etc. Essentially anything that would damage a 'normal' car in any meaningful way will crack a clam. Front clam is usually a bit more expensive at the dealership as there's other things that tend to get damaged.
Keep in mind, the clam itself is only about $2500 and MOST of the time can be repaired and painted for less than $1500. Fiberglass is very cheap and relatively easy to work with. Most people want a new clam though and they call them "stealerships" for a reason. ;)
Very fragile, a fly hitting the clam could crack it. Thats why the mileage on these cars are soooo low.
Seriously though, its not THAT fragile...but a 3-4mph bump could crack it, theoretically.
Cost depends on where you go....8k-12/14k
i doubt a rock from another car would crack the clam...unless your offroading.
what kind of damage occurred to your clam?
The winglet bit on the bottom of the clam got damaged, visible crack, whole area smaller than a dime. I sanded it down and then applied new fiberglass and repainted.
I might have been able to avoid fiberglass if I had been more careful sanding as I underestimated how thin the clam was on the winglet and ended up with repairing a larger area than the original crack. Though to be honest the fiberglass in the area was loose to the touch so I think I did need to sand away as much as I did.
For an amateur repair job it came out ok. You can see in these pictures how much of an area I cleaned when sanding.
i hit a raccoon at about 35 mph, cracked the clam, ruined the grille.
i fiberglassed the inside of the clam and replaced the grille.
not really fixed but it's functional and the crack won't spread.
later hit a deer at about 2 mph, deer fell on clam, got up and walked away.
replaced radiator...and grille.
still need the 'roo bars..:wallbang:
sam
· Vendor
Exige clams are WAAAAAAAAAY tougher. I've had both and they're not even comparable. I feel like I can run over a herd of deer with the exige clam:D...
Seriously, it really can take a beating by comparison (still fragile compared to most cars though)... It's also more conducive to repair since it doesn't flex as much...
Regarding replacement, a chimp could replace the clams on these cars. People need to be just a little more adventurous and try doing their own clam replacements (and work on their cars more in general;)).
Have a body shop finish and paint a replacement clam and do the removal/installation yourself over a weekend with a neighbor and case of beer… and save a few/several grand...
There's plenty of documentation about how to do it right here on LT and it requires all of 3 hand tools available at home depot. We all were born with a knowledge base of zero and most on a forum like this likely has a higher IQ than their local body shop guy. I assure you that you can do the work and figure it out... Plus you'll have learned something in the process:up:
My 2 cents...
Best,
Phil
My 2 cents...
Best,
Phil
I don't think anyone (rational) actually pays $15,000 for a clam replacement when insurance isn't involved, and if they are, might as well save yourself the time and have the dealer do the work. The price is ludicrous. Anything over $2,000 for a replacement is ludicrous in my eyes, but they don't really care what I think. :p
· www.theapexinn.com
1 - 20 of 27 Posts
