1 - 10 of 10 Posts
It is an odd quirky factory option, the seat lumbar adjustment. How many cars out there have it? It is basically a bulb (much like on a blood pressure cuff), which you pump up to inflate the lumbar portion of your seat, and a valve to let the pressure off (once again like a blood pressure cuff). My car has it on the driver and passenger side. I saw another Elise that had it, on the driver side only.
The lumbar bladder was standard on all federal 2005s. I think if you found one that didn't then it was removed or the seat had been swapped. The probax seats available in 2006 and beyond don't have them.
My '05 has it on both sides. The driver's side is worthless though - air pressure doesn't hold. I slid a block of 1/2 inch wood in there and support is consistently firm.
The black seats which I believe to be original had bulbs both sides. The biscuit seats I bought used to replace them have bulbs both sides. They all worked fine.
Wouldn't want to go without this feature.
Boony - this can usually be repaired easily. The plastic tubing gets brittle over time and develops a leak. You can cut out the part that's leaking and then use vacuum line to splice it back together. This is how I repaired mine - instructions exist on LT if you search. If the bladder is ruptured, you may be screwed...
1 - 10 of 10 Posts
