1 - 20 of 24 Posts
This is the lighting harness for the trunk, which, logically, needs to be disconnected to replace the rear glass.
I see a tab that need to be pushed or pulled or somethinged, and I've had zero luck so far. Before I stab my hand with a flat blade screwdriver, can somebody give me a definitive method of undoing this bit¢h?
That's it, push it together first to relive the pressure on the little nub. Pry the tab up then pull apart.
Ummmmm, so far nothing. Anybody have experience with this particular connector and have the stitches to prove it? :crazyeyes
Should be straightforward, but it ain't. The fact that it's covered in tape shmutz ain't helping.
Maybe I should donate my own blood first.
Sawzall!
Discussion Starter · #9 ·
Thanks Harix! Now I know EXACTLY how I'm going to bleed (or that the blood won't be spilled in vain)!
Don't pull the connector straight out. Wiggle it while pulling it out. I tried to pull straight out. Didn't work out so well but wiggle wiggle rock rock wiggle wiggle worked great.
Discussion Starter · #11 ·
I'm using a flat blade screwdriver pushed into the slot and levering down on the tab. Am I defeating something?
Yourself! Walk away from it for a bit. Then try again
I don't think that small tab on back has diddly to do with it.
Use a small flathead, slide it under the big tab over the locking nub and pry aft. If you break the tab off it will still work later.
Ill look at mine when I get home.
Discussion Starter · #14 ·
Lots of side-to-side wiggling as per RoadDad. Lots of pulled tendons in right hand. Seriously considering cutting harness and replacing connector. In the morning after qualifying.
Discussion Starter · #15 ·
Morning now. Soaked the connector in penetrating oil overnight. Still won't budge.
Tried disconnecting individual lights and shoving large connector through clam hole. Of course, there's about a 1mm clearance issue and I really don't want to ream out the hole to clear it (I hate bodge work).
Off to auto parts stores to find generic 6 or 8 pin connector and if there is such a thing, I'll cut and re-terminate. Bodge work, but will look and function as good as factory work.
Any better ideas??
Discussion Starter · #18 ·
Thanks again Harix. I've tried and tried and that sucker wouldn't budge! Very weird. I've purchased a Molex connector to replace it with and hope there isn't a resistance issue and subsequent fiery death.
A1 Automotive & Smog
Ok then your connector could be melted because of heat due to loose connection(s) from one or more pins.
Anyway, to replace the rear glass, I think the clam doesn't need to be removed completely. So try get a couple of box about 20 inch high, remove all screw hardware, with two people, you can lift and back up the clam a few inches until the wires held it and your clam going to sit into that box. I never try, but a few inches opening on to enough to install the glass.
Are you going with OE glass or Plexi?
Discussion Starter · #20 · (Edited)
Already pretty deep into the project.
Pics here: https://www.facebook.com/EricScottW...0202041362015042.1073741830.1216231277&type=1
:panic:
There was some signs of battery-type corrosion on a couple of the pins, so I'm sure that played into it. I'm debating whether to go with the Molex connector (MolexKits.com | 76650-0055) or butt splice (permanent).
The Molex is rated at 5 amp (each circuit), I haven't checked the fuse rating on the brake light circuits, I doubt they are more than that.
If I can acquire the OEM part, I'll install that as soon as I get it.
1 - 20 of 24 Posts
