I have been beatign my head against the wall... My passenger door wont open form the inside. I thought the linkage had become disconnected but when i pull the handle i can see the little white polymer flipper lift but not high enough to release the catch. When i press the exterior button the flipper lifts much higher and releases the catch as normal.
But i now noticed that that door sages just a bit more than enough that the the inside would then release and work as it should. I found this post
http://www.lotustalk.com/forums/f92/door-sagging-21693/ it shows the hinge lay out but how do i get to it?
