1 - 20 of 33 Posts
IMO, it is essential to have the service manual prior to working on the Elise/Exige, to figure out why your car threw a code, etc. It is very handy to have this information available in digital form, especially in a searchable PDF format. Instructions on how to download the manual from Lotus are buried in a few threads on the forum here, but the threads are very long and it can be difficult to find the instructions that work in the threads. So, to make life easier for everyone...
This is the method for obtaining the Lotus Elise/Exige Service Manual, Parts List and TSBs in PDF form from Lotus for $25*.
  1. Start here: Lotus Subscribe.
  2. Click "I Agree"
  3. Sign up and pay to be a "subscriber" by choosing and entering the required information: username, password, email, first and last names. You can obtain everything available with the 24 hour option for $25.00 (first of the three options). You can sign up for longer if you wish to give Lotus more than $25 because you have cash to burn.
  4. Open the email account that you used to register. You should receive an email with your Subscription Receipt for Lotus Tech Info. This sometimes takes a bit of time.
  5. After receiving the email, use this link Lotus Subscriber - Log-in to get to the download site.
  6. Sign in with your user name and password and download away.
For those who prefer a hard copy but don't want to pay the $$$ for the official available through the dealership copy, you can download the PDFs from Lotus, have them printed and bound at your local Kinko's. It is not very expensive comparatively to do so.
Or you can use them on a laptop in your garage although I personally find that very frustrating and I get in trouble for the grease and grime on the laptop keyboard and monitor.
*Non-US users, I am sorry but this does not seem to work for you unless you have a US paypal account.
Discussion Starter · #2 ·
There is an alternative site for downloading service note information from Lotus for 5 euros per hour, 15 euros per day, 45 euros per week, 250 euros per month or 1200 euros per year. I do not know if this works for US customers or not as I have not tried the site. It contains Evora info as well as Elise/Exige.
Lotus - Vehicle Service Information
I'm trying to download the manual, but all I see is emissions-related documents - how do I find the service manual for an Elise?
Those documents are what you want... just download everything on the site. The service manual and service bulletins (TSB) are in there.
After downloading everything, would you be so kind as to list the TSBs that are there? Frequently the question is raised as to the most current TSBs available.
Elise/Exige TSBs as of 3-29-11
TSB 2008-05 Cup 260.pdf
TSB 2008-06 schutz.pdf
TSB 2008-07 exhaust clamp .pdf
TSB 2008-08 rad hose 2.pdf
TSB 2008-09 camber shim.pdf
TSB 2008-10 Accusump valve.pdf
TSB 2008-11 2-11 mirror.pdf
sb_2008_12_IP calibration.pdf
sb_2008_13_sandwich plate.pdf
sb_2008_14_screen seal.pdf
sb_2008_15_rod clip.pdf
sb_2008_16_europa se.pdf
sb_2008_17_09 Cup 260.pdf
sb_2009_01R USA hub bolt.pdf
TSB 2009-2.pdf 88.52 KB
sb_2009_01R_Issue 2_hub bolt.pdf
sb_2009_03 horn relay.pdf
sb_2009_04_abs.pdf
sb_2009_01_track use 2.pdf
TSB 2008-01 Elise SC issue 2.pdf
TSB 2008-02 2-11 rework.pdf
TSB 2008-03 grille retrofit.pdf
TSB 2008-04 2-11 oil hose.pdf
TSB2010-11.pdf
26. 2-Eleven Supllement.pdf
TSB 2004-11 Throttle Setting Procedure.PDF
TSB 2004-21 Cnnctn checks Front Oil Coolers.pdf
TSB 2005-03 2nd 2 Scan 3 USA Version.pdf
TSB 2006-07 ECU update program.pdf
TSB 2006-10 Electronic Throttle Body.pdf
TSB 2006-20 AC Module.pdf
TSB 2006-25 Scan Tool Disc.pdf
TSB 2006-26 Chargecooler Duct.pdf
TSB 2007-07 06MY Reflash.pdf
TSB 2007-08 Exige S Reflash.pdf
TSB 2007-09 Exige S Air Leak.pdf
TSB_2007-16 08 MY Info.pdf
Evora TSBs as of 3-29-11
TSB2010-11.pdf
sb_2009_11_evora susp plus.pdf
SB_2010_14_LHD Federal Evora Footrest.pdf
sb_2009_05_ac dowty.pdf
sb_2009_06_tooot1519.pdf
sb_2009_07_gear knob.pdf
sb_2009_08_knock.pdf
sb_2009_09_fuse.pdf
sb_2009_12_heatshield.pdf
sb_2009_13_door drain.pdf
sb_2009_15_issue 2 evora water.pdf
sb_2009_16_door.pdf
sb_2009_17_isofix.pdf
sb_2009_18_program.pdf
sb_2010_01_siren fuse.pdf
sb_2010_02_silicone mtgs.pdf
sb_2010_03_drain tube.pdf
sb_2010_08_calib.pdf
likes to drive fast
Hey all,
Hoping to get some pointers. I just signed in today and I can't seem to find the parts list, ie parts catalog?
Thanks.
Hey all,
Thanks.
Same problem here. Loaded down all sorts of TSBs but couldn't find a parts manual. I'm specifically looking to find information related to the drivers side door internals.
Steve
another site has these up, but when I tried, only one of the links worked, maybe you'll have better luck?:
DLS3E0259F - Fitting Instructions Laminova Oil Cooler.pdf: DLS3E0259F - Fitting Instructions Laminova Oil Cooler.pdf - iPut It
Elise & Exige Service Parts List.pdf: Elise & Exige Service Parts List.pdf - iPut It
Lotus Elise S2 Owners Handbook.pdf: Lotus Elise S2 Owners Handbook.pdf - iPut It
Lotus Elise S2 Service Notes (2004).pdf: Lotus Elise S2 Service Notes (2004).pdf - iPut It
Lotus Elise SC Kit Install Ver2.pdf: Lotus Elise SC Kit Install Ver2.pdf - iPut It
Lotus Service Bulletins (2004-11 to 2007-16).pdf: Lotus Service Bulletins (2004-11 to 2007-16).pdf - iPut It
Toyota 2ZZ-GE Repair Manual.pdf: Toyota 2ZZ-GE Repair Manual.pdf - iPut It
Toyota Celica Repair Manual (Volume 2).pdf: Toyota Celica Repair Manual (Volume 2).pdf - iPut It
  2. Click "I Agree"
Never mind.......I answers my own question. It was a MAC thing.......
It is confusing but the TSB are the manual -- for example open this up in the emissions sub category ( 05.%20BR%20Body%20Fittings ) and you will find the manual for the body fittings.
Best advice is to open up a few and look -- then just download them all and then try to categorize them.
Just downloaded all the files. I've been building websites for 7 years and I've never seen something that should be organized and labeled in a user friendly manner in such discord, I can’t believe you have to pay for this garbage. To get these in a useable format it’s going to take days of reorganization. I expected Lotus to have a single PDF file for each model year, all in order and ready to go. Their lucky I don’t host it for free on my server and mass email the link to all LT members.
Your kidding right?
This is a low volume car not a Honda Civic. If you haven't already noticed everything about the car is going to be low volume, a little "different" and unpolished compared to any run-off-the-mill vehicle. That is something you just have to live with once you buy a Lotus.
Lotus is letting you pay $25 to download all of their service manual documentation. You are paying for the documentation not the website. I don't care if its in ftp, wiki, rainbow colored web links, etc. As long as I get the manuals, $25 is a steal.
Thanks to the OP by the way. These manuals have been well worth it for all the work I've done on the car.
Your kidding right?
I'm with you... Try getting a manual for a newer Porsche 911. The only reason I got mine is because someone had a hookup at a stealership. Otherwise it's thousands a year to use their website.
How long do you have to wait for the email response after signing up and doing the paypal purchase? I have waited over 12 hours now, with no email response, and the money has been taken out of my paypal account. I also tried logging in with my username/password, but it says:
Your account has either expired or we have not yet confirmed your payment from PayPal.
1 - 20 of 33 Posts
