1 - 2 of 2 Posts
The passenger side window won't go up, but it goes down. I removed the switched and checked it and the switch is 100%. However if I move the wire harness to the switch a little. It works again.
How do I remove the wire harness from the door?
Discussion Starter #2
solved it, you have to remove the door handle.
The trick to the door handle is a hidden plastic clip that holds the metal opening rod down into the handle.
Pull the door handle open, then twist the white plastic holding clip towards the inside of the car.
1 - 2 of 2 Posts
