What didn't you like about your other one?thanks guys, I'm trying new grill idea since the other one i made was not 100% perfect.
I actually used zip ties that attached to the clips on the top. The bottom in just resting against the clam. After quite a bit of tweaking I was able to make the curve just right so that it is rest right against the front of the clam. I did place a small section of foam around the lower portion of the tow hook to help hold the center section tight against the front of the clam. The screws that were in the pictures of mine were just put there to fill the holes in.The bends I made werent perfect, I'm going to try and attach it from the back like you did. Did you just bolt it to the top part of the clam through the clip holes? Any advice on mounting it? I appreciate it!!
