How To Set 2011 Lotus Elise Clock
The 2011 Lotus Elise clock in the instrument cluster, unlike previous years, is always displayed. The image below shows a time of 16:30.
The owner's manual (including supplements) does not describe how to set the clock. Through trial and error, I figured out how to set it:
1) Turn the ignition key to position II (2).
2) With the engine off, tap the set button on the steering column until the odometer is displayed.
3) Press and hold the set button (about 2 seconds) until the clock hours flash. Then tap the button to advance the hours (note that time is in 24-hour format).
4) Press and hold the set button until the minutes flash. Then tap the button to advance the minutes.
5) Press and hold the set button until the clock reverts to normal display.
Hope this helps someone else in the future...
