1 - 20 of 22 Posts
2007 Lotus Exige S
Great video and commentary. Did your shifts feel noticeably different once you took it out for a drive?
Less is Better
Discussion Starter · #4 · (Edited)
I did get a chance to drive the car really briefly. I'm planning to get my cameras in my car and record a drive when the weather clears up.
The shifts feel great, very mechanical and direct. The sift throw is nice and feels natural. The shortened crossgate throw eliminated the interference with the console in reverse. I think my mechanism must have been in pretty good shape to start with though, so it's not a night and day difference, pretty subtle. I've seen videos of other people's cars where everything is completely sloppy and would really detract from the enjoyment of the car. This would help those cars immensely. But then again, so would a fresh stock system. This vid from Mr. Steele showing the shift action around 1:09 would have had me pulling out my hair, for example.
Frustratingly, the buzzing in the shift mechanism that I was getting at 4500-5000 RPM is now there from 2500 RPM up. It really detracts from the experience to have what sounds like a loose screw buzzing away all the time. This is a new problem that showed up when I did the SSC cables and ShiftR111, it seems like the LETSLA has made it worse.
Overall, I'd say LETSLA is a really nice piece of hardware, made from high quality parts and materials that are going to last a LONG time. But as I concluded with the ShiftR111 and SSC cables, if your shifter is in good shape, you're not going to notice much difference. For me, I was just really curious to see how much better my stock system could be, and I like to work on the car. I have no doubt though that the LETSLA and other parts are much more robust and will last much longer than the stock parts so it's a useful upgrade for piece of mind for someone looking for that.
My reaction to the ShirtR111 and new cables was the same as yours: not a lot better than stock.
I read here recently that putting a bungie cord on the transmission linkages can eliminate a rattle like the one you mention. Maybe the author can chime in.
I’d check the routing of your cables. Did you use the hanger to hold the shift cables above the engine pan? Maybe one of the cables is vibrating against the pan.
Less is Better
Discussion Starter · #7 ·
Yes. That was actually the first thing I did. I added padding at the zip tie down point at the back of the transmission.
1998 Elise Duratec, 2009 Exige S240 (+TVS1320 / CC)
Ive owned a lot of 2zz powered Lotus', mainly with low KMs use . The gear change shift quality was different almost on everyone. I never adjusted or uprated any of them, its just how they were when I got them. On average, I'd give them a 6 out of 10 score.
By far my 2-Eleven had the best gear change action (2007, so prior to the later 'blue ball' mech) - just snick-snick every gear, no matter what speed you changed. It was VERY low KMs, as is the nature of 2-Elevens.
So I agree with your point above. If you have a low use 2ZZ powered Lotus, in good condition & well adjusted, theres no reason why the gear change can't be an 8 out of 10
Less is Better
Discussion Starter · #11 ·
I figured out how to fix the extra noise from the shifter and the good news is, we all can do it (except for a few of you Exige guys)! Drive without the top on, just as the big guy [Colin Chapman, who do you think I meant?] intended. Not a hint of an offensive noise, just mechanical, crisp, enjoyable gear shifts at redline. Ah I love this car!
Less is Better
Discussion Starter · #12 ·
I think I may have successfully stopped the shifter rattle that I mentioned and you can hear in my videos. I thought I would look at vibration of the cable in it's sheath. I decided to lightly wrap the two cable inner sheaths together as they exit the outer sheath at the transmission bracket, see the picture below with the black tie wrap around the cables. I figured if there's something slightly loose, all it should take is slight pressure on the cable sheaths to change the frequency of the vibration for it to go away. It appears that it has worked (knock on wood).
1267517
Less is Better
Discussion Starter · #13 ·
I'm finding that the LETSLA cable stop bracket forces the sheath to too much of an angle relative to the cable for the shift cable with the cable set at the second longest throw. I started feeling friction/grinding when going into 1st, 3rd and 5th, not good. I tried setting the shift cable to the 3rd position in throw but it's just too stiff and hard to get out of gear. The second spot from the outside is the ideal spot. I lubricated the cable and it's much better, but I'm going to go back to the stock cable stop bracket, it has a friendlier angle for the sheath for the second longest throw on the LETSLA. It wouldn't be a big deal but the cables have to be readjusted afterwards, with makes the job 3x more work than it would otherwise be.
Thanks for documenting and giving your input. I actually have a LETSLA kit sitting in a box. Haven't installed it yet. Still not sure if I will...I'm not too bothered by the current state of my stock shifter.
Did you have the angled spacer for the LETSLA bracket that was part of the 2nd gen upgrade? That spacer put the cables at a better angle. I've been using the second longest throw settings since I installed it 3 years ago with no issues, with the Inokinetic cables.
Less is Better
Discussion Starter · #16 ·
Yes. It's not the vertical angle, it's the horizontal. The cable makes a pretty significant left turn as it comes out of the sheath.
Out of curiosity, do you have any shifter vibration/rattle?
No vibrations or rattles out of the ordinary. I'll try to get a look to see what angle my cables are at, though I can't imagine why it would be different than yours (with the LETSLA bracket). What cables do you have?
Less is Better
Discussion Starter · #19 ·
I have SSC cables.
Less is Better
Discussion Starter · #20 ·
I have to give another "shout out" to Troy. I emailed him just to make sure he didn't see any issues with my re-installing the stock bracket. He volunteered to send me a bracket with the shift cable spaced over further to align it better with the outside mounting point to see if that would address my concern instead! That was so cool of him! This should help to avoid me having to readjust the cables when I swap brackets. When it comes in and I install it I'll report back.
1 - 20 of 22 Posts
