1 - 14 of 14 Posts
I have a new back injury which will most likely lead to surgery #3
This causes me Great Concern.
With my back fused now I can barely get into my Elise now. I think it’s going to be nearly impossible with an additional fusion.
Here’s where I need everyone’s help. At one time there were Gull-Wing roofs made for the Elise - see this link
Hunting Ridge Motors: Lotus Elise Gullwing Hardtop
If I can find a roof like this I will be able to keep a car I dearly love. I have spent a furtune getting it just about perfect and not this - ahhhhh
If you know of anyone who is using a roof like this ask them if they would consider selling it.
If YOU have one - I would REALLY like to make you an offer to buy it.
Thanks everyone for your help....
Or, have the spring loaded part moved to the opposite side of your soft top. Then just unroll the soft top roof from the driver's side and climb in. Roll it back and click it in place. Moving the spring to the opposite side will make it less likely to tear up your roof gasket when you undo the roof from the driver's side. This is a far less costly option.
this may sound a bit crazy, but if you can't find one, i wonder if you can retrofit a full one...like cut in half, etc etc...make something custom for yourself. granted, it'd be a lot of work and research in finding the right solution, but it may be worth it over you not being able to use your car...
The guy I bought one of my Elise's from was way overweight and totally sedantary....the only way he could get in and out of his elise was to release his soft top as you suggest...
Although, not sure what you mean by the spring loaded part moved to opposite side...both sides are spring loaded. He just reached up, pulled back the mechanism on the driver's side, partially unrolled the top, got and, rolled it back.
I am talking about the small cylinder (about 2.5 inches long, 1/2 inch diameter) which has a spring loaded cable tensioner. The tensioner is on the driver's side. It tends to eat the rubber seal under the soft top if the roof is loosened and tightend from the driver's side, which is why the manual for the car states to undo the roof from the passenger side. Moving the tensioner to the passenger's side will make it to where the driver's side can be undone and latched without risking the roof seal.
If you can find one of those made in England gullwing tops just be advised that they're pieces of junk in fit, finish, and function as delivered. I saw one in '05 that needed more money in fixing it than it cost, so hopefully you'll find one that's already been fixed.
1 - 14 of 14 Posts
