1 - 20 of 40 Posts
Well, I just wanted to share a photo of my calipers on my 2005 Starlight Black Elise. I couldn't stand the flat grey tone from the factory, so $19.99 later plus some time I am all set! I wanted something that looked class. Not too flashy, but nice. I went with gloss black with gold lettering on the Lotus script. Just curious what people have done to their cars brakes/calipers?
Thanks!
Thanks! The hardest part of the job was taking the wheels off. I really enjoyed doing this though. Now the car looks a little better too!
Nice. I never considered black, I like it. You should have did mine at the same time.
Sent from my Autoguide iPad app
Looks great. :clap:
I'm planning on doing mine, just haven't had time to get it done.
Did you did the rear wheels as well?
How did you do the lettering?
Ticket Magnet
Your entire car looks great!
I love that your wheel bolts are not all blemmed too.
This is such perfect timing.
I want to powdercoat my calipers but am not sure how to prep them to best protect the cylinders from the process so I have been considering painting but am not sure which paint would be heat and brake dust resistant. I am thinking that brake dust is very corrosive, but please correct me and recommend the best rattle-can brand paint to use!
Looks great. Looks clean and OEM which is what I like!
Out of curiosity do you track your car at all? I always wondered how aftermarket painted calipers hold up to the extreme heat.
Looks great.
Also, I like the time warp of that photo. Late 80's two tone Thunderbird in the background.
Remember those?
Discussion Starter · #12 ·
Looks great. :clap:
I did the rear as well, but they are so small and plain that there isn't much to see on those. I used gold metallic model enamel for the Lotus raised letters. Use a small brush and trace along the raised letters. You can always touch up the edges of the letters if you blob the paint with a very small paint brush and more caliper paint. Have fun!
Ps I applied the gold while the black was still curing. I hope this helps the gold to bond well.
Discussion Starter · #13 ·
I have done my calipers on a couple of Porsches that I owned and I used a spray caliper paint once and a brushed on caliper paint once. Both were purchased at the local parts store. I recommend the brushed on paint kit $19.99. No overspray and it is really easy to apply. On my Porsches it held up very well. If it ever needs touched up I have a ton of leftover paint in my kit still. I have seen expensive caliper paint kits, but the cheap kit at O'reilly's has worked well for me.
Discussion Starter · #14 ·
I have not tracked the car, but I will be trying to heat the brakes up soon:)
Also, when you have the wheels off, it is a good idea to clean and wax the inside and outside of the wheels. My wheels dust up very badly so I hope this will help make them easier to keep clean.
There is high temperature caliper paint available. My son painted the calipers red on his Mini Cooper S and they turned out fantastic. He used the G2 Caliper kit.
Those look nice as does your car. Very clean, I'm wanting to paint mine too, but I'm going to do a yellow to contrast with my metallic green.
I'll probably get a G2 kit as well. I've read some good things about them.
1 - 20 of 40 Posts
