1 - 1 of 1 Posts
Hi all,
First off, I apologize for no pictures - I had to get everything back together so I could drive my car into work.
I was mucking around with the ignition switch of my Exige when the ignition switch popped apart and stuff went flying everywhere - for the third time that day. I was able to gather up everything (two small "Y" shaped metal connectors, small rectangle piece of plastic with a nub, and the round piece of plastic they sit in) except the small spring that pushes out the rectangular piece of plastic. I put things back together and it works, albeit very sloppily.
If I want to buy a replacement, I think that what I need is the ignition switch as described in this thread:
http://www.lotustalk.com/forums/f259/ignition-switch-109397/
If I understand correctly, I need to pop off the piece of plastic holding the four wires by releasing a retaining barb, remove the old ignition switch (not sure how yet - hopefully the manual will say), and re-install.
Am I on the right track here? Or does someone out there have a source for the really small spring?
Thanks!
1 - 1 of 1 Posts
