Lotus Cars USA, Inc. is proud to introduce the 2009 Lotus Elise - Purist Edition. The Purist
Edition Elise gets back to the basics of “Performance Through Lightweight” and features a
lower base MSRP, all while retaining the true essence of a Lotus: Everything you need, and
nothing you don’t.
Base MSRP: $43,995*
Exterior:
• Lotus-designed lightweight epoxy-bonded, extruded aluminum chassis
• Integral steel seat-belt support structure and lightweight steel rear subframe
• RTM Composite fiberglass body
• Removable soft top with stowage bag
• High intensity projection beam headlamps
• LED taillights with integral reflectors and daytime running lights
• Aluminum alloy fuel filler door
• Aerodynamic rear diffuser
• Standard paint colors- Ardent Red, Saffron Yellow or Monaco White
Engine and Driveline:
• 1.8 Liter, 190 hp, mid-mounted 16 Valve DOHC 4-cylinder engine
• Multi-point fuel injection system with electronic ignition and throttle
control
• 6-speed transaxle with lockout reverse gear
Interior:
• Black leather seats with Probax anatomical padding
• 4-speaker stereo with in-dash CD player
• Leather-trimmed Momo steering wheel
• Sound deadening insulation
• Central door locks and intermittent windshield wiper
• Air conditioning, starter button, tinted glass and carpeted foot mats
Suspension and Braking:
• Fully independent suspension with unequal length wishbones
• Bilstein gas dampers, Eibach coaxial coil springs and front anti-sway
bar
• Power assisted 4-wheel ventilated/cross-drilled disc brakes
• Lotus/AP Racing & Brembo calipers with anti-lock braking system
(ABS)
• Silver finished alloy wheels – 5.5JX16 front, 7.5JX17 rear
• Yokohama Neova high performance tires – 175/55-16 front, 225/45-17
rear
Safety and Security:
• Dual supplemental restraining system with seat belt pre-tensioners
• Factory anti-theft alarm system with engine immobilizer
• Tire pressure monitoring system, progressive shift lights
• Power door locks with remote control
• Door remote integral with key
• Concealed radio antenna
Warranties:
• 3-Year/36,000 mile limited warranty
• 8-Year chassis corrosion warranty
Options
Call Max at 864.232.2269
nothing you don’t.
Base MSRP: $43,995*
Exterior:
control
Interior:
bar
(ABS)
rear
Warranties:
Options
