1 - 4 of 4 Posts
With the supercharger kit installed some very large orifice injectors. Both at the top and bottom of the injectors there are black rubber cups rather than o-rings. I am looking for a part number and place to get replacement cups (seals). Can anybody point me in the right direction? Much appreciated.
Those I believe are the "isolators" like a thick washer made of rubber.Those do not usually leak as they are not under pressure. They go on the injector closest to the head. The O rings go into the fuel rail and stock size works best. If you have a leak it is most likely a leaking O ring or mis-alligned fuel rail. Make sure the tapperd seats are fitted correctly for the 2 bolts that hold the fuel rail. Tommy
1 - 4 of 4 Posts
