1 - 3 of 3 Posts
Is anyone out there currently using an Innovate OT-1?
I'm having problems with my dash instrumentation only when the OT-1 is attached... my tach and speedo go to zero every few minutes (for 5-30 seconds at a time), and my fuel gauge reads a bit low. If I disconnect the OT-1 and restart the engine, everything is back to normal.
The OT-1 itself is working fine, and logging all the parameters that I ask (up to 12 at a time so far), but losing my tach and speedo is an annoying side effect.
Did you ever sort out the problem?
I was told it is a common side effect and not OT-1 specific.
Yes, I had to internally disconnect the CANBus pin from the OT-1... after that the interference stopped completely and I'm able log OBD-II parameters. Unfortunately it seems I'm not able to log 12 parameters at a time as before, but only 6.
1 - 3 of 3 Posts
