1 - 4 of 4 Posts
Had these carbon fiber boards installed and really happy with them. Next up is carbon fiber air side scoops which should go great with them and tie in carbon fiber rear hatch and access panel. Thanks again Greg for the great service!
Nice!!! Greg is awesome! I installed the same one a little while back. I also added a body color line underneath. I started with just coloring the edge of the boards from Greg first, then added a half inch L shape aluminum piece under them...with body color. Still debating which ones to keep.
Also had the third cat delete pipe. (what a difference!!)
Front splitter for me next...now maybe the air scoop, I think that's a glue on for the 400?
Reactions: Redsled
I think you can glue or use double sided tape. I have had found double sided tape works great so will go with that and then use epoxy to give it a finished look. I also installed GRP decat pipe along with Larini exhaust and it sounds amazing
You can also use Sugru to attach the side scoops if you don't want to glue or tape them.
1 - 4 of 4 Posts
