1 - 3 of 3 Posts
I guess I just suck at the search function! Can someone please show/tell me how they installed the override?? Where and how to wire it and where to put the funky doo dad? I found one link for instructions but you have to pay to view it!
Thanks!!!
Gamera The Atomic Turtle
the fancy do dad imo can go up by the third brake light, tucked under next to it. You need a ground, and i believe you can use the one the light is using. If you have a clam hinge - this may not be a convenient spot - Sir Lotus can give you a clue. The long yellow wire connects to the alarm module - do not know which pin, but Michael does. Alarm module is located in the passenger cubby - you will bleed getting to it through fields of barbed wire and razor sharp aluminum.
1 - 3 of 3 Posts
