1 - 14 of 14 Posts
I’m looking to do the Triple gauge stack in between the console and climate controls. The aluminum one that is made to look factory/OEM. I like the 52mm revel/VLS oled blue ones. Boost, oil temp, and pressure.
1. Id like to know who’s done this before to see if things need to be cut or modified to get the bottom gauge to fit. I’m not afraid to cut or modify that small aluminum foot separator piece.
2. Best way to run power and ground. Go off of a fuse or radio wires?
3. I’ll be installing a mishimoto sandwich plate and baffled oil pan. Would there be benefits to putting the oil temp in the pan over the sandwich plate or vice versa?
Any advice is appreciated. Thanks in advance!
-Brandon
I did AFR , oil temp and pressure. For the bottom gauge you need a very short one like the AEM X series. I got the power from the fuses in the passenger foot well, and grounded under one of the screw that secured the top of the gauge panel.
I have the Mishimoto plate as well and got my oil pressure from that, oil temp is installed in the TOC oil pan. All connecting wires routed the same as the shifter cables.
This helps a lot. I saw you original post when you did yours about drilling a hole too. I’ll prob go the same route. As for the bottom gauge, I’ll dremmel out whatever space I need. If I ever need a replacement they’re under 50 bucks on eBay.
I want my gauges to come on when I press the ignition button. Is that how yours work or do you need to press the headlight button?
1259889
you could also get a combo gauge that shows oil T and P on the same gauge. you can also get AFR/boost combo gauges. In my opinion I like less gauges with more info.
My gauges are wired so they turn on, including the gauge lights, when I start the car.
Is there a way to move the obd2 connection over a little or is this just blocked and gauges moved when needed?
He's on fire!
I have this same problem, different gauge cluster. What I did, was install a wireless ODB2 connector before installing the gauges. Now I can read it anytime I want without moving anything. If you have to deal with emissions or someone else servicing your car though, this solution would still be problematic. the odbc connector itself is just screwed in by two screws, I bet you could relocate it... or they also make odb2 extension cables, that could also solve the problem.
I didn't do the guage cluster as pictured because I thought my leg would regularly come in contact with it while driving.
Discussion Starter #10
Ahhh that’s a great idea! I’ll likely grab the right angle ribbon extension for 10 bucks on amazon.
I moved the OBD2 port over to the right so the left side of the port lined up with right side hole, and then drill another hole for the right side of the port. Hope that makes sense.
Here are a couple of pictures of the OBD2 port and the wiring.
1259899
1259900
Since my car have plenty of gage, I am using a tri-pod in the front of the shifter, as many driver, for the less critical gage, Oil pressure, oil temp and fuel gage (yes because my car is too much modified...).
By I am also using a tri-pod Autometer 5288 in the top of the dash for the more critical gage (boost, AFR and Air temp). My car is turbo. I pretty like this tri-pod, well located, and easy to install with a split box.
1 - 14 of 14 Posts
