1 - 6 of 6 Posts
Hi, I am trying to install a second hand SCC shifter cables and I run into the problem on the shifter side.
Seems that the ball end fitting is pressed into the shifter mechanism. And the SCC cables use a threaded bolt.
Do I drill out the ball fitting?
Hope it makes sense.
1264137
Administrator
Yes glad you found it. One of the best mods I've done but I need to tweak the adjustment just have 1000 mi on new cables and cables may have stretched slightly.
I drilled mine out. Is that what you did?
07 Exige S
That's what I did. I did however have the new ends loosen up on me and no shifting. Had to take console out and retighten by hand on side of road. Once I got home Locktight blue!
1 - 6 of 6 Posts
