Hi there! Why not register as a user to enjoy all of the benefits of the site? You may register here. When you register, please pick a username that is non-commercial. If you use a name that appears on any search engine commercially, you must pick another name, whether it applies to you or not. Commercial usernames are for supporting vendor use only. If you want to become a supporting vendor and grow your business, please follow this link. Thanks!
Awesome thanks @Riceburner98. I tried simply just heating up each one individually and using a set of tweezers to pull it off but had no luck, its going to take me a little bit :/ With the solder trick you mentioned on the one side I assume you added extra solder to make it one solid blob? And when you put the new one in I assume the one solid blob cant stay there??
Yep! I add enough solder across the 2 pins to make a solid blob, and can add more to the 1 pin on the other side as well. Basically creating a larger mass to hold the heat and keep it molten while switching sides.. Then remove as much as you can from the pads when re-installing. Technically since this is a diode (which only uses 2 pins, the 3-pin package is just for convenience I think? So it can't be installed backwards), so the 2nd pin on that side is unused and leaving them blobbed together wouldn't electrically change anything. Those always confuse me because that package is typically for a transistor with 3 pins..
So replaced the diode last night and everything seems to be working again. After putting the new diode in I tested it just like before with the original white el panel which seems to be dead. But plugging in the stock on worked. I replaced the original white with the new one and we are back up and working again. 3rd times a charm. Hopefully I dont have to do anymore soldering on the board :/ That was a pain but Riceburner98's method of adding solder and heating both sides up worked like a charm but I did need to asked my wife to man a set of tweezers. Thanks for the help @Riceburner98.
Anyone have an issue with the tach needing to be reset to factory position after this? My install was kind of a mess because I had to replace both motors at the same time. Got the recommended replacements, ground off the standoffs and soldered in. Speedo works great, but I'd say about every 5th or 6th start up, the tach will stick about 1k RPM higher. Doing the gauge reset (open driver side door, pull 7.5A fuse and key on while holding odo reset) works, but a few weeks later, it comes right back. Never had this happen in the 2 years prior.
I had an issue with both of mine sticking. Look how fast I'm going!!
This was because the plexi was barely contacting the top of the needle hat and would cause it to stick on rare occasion. I had to pull the cluster out and raise the plexi up a little bit so it wasn't rubbing on the hats. Has been perfect now. So check to make sure it's not barely contacting.
Thanks guys for all this, I used this info and a few other threads to install my own guage cluster face today. I have it now 100% black with white light.
Thanks for the reminder! It has been a busy couple weeks trying to get the house ready for our party.. Finally finished with the 'house' part (the day of the party, I was working until the first people showed up!), now taking a vacation (Texas) for a week then it's on to building the new workshop. Garage will probably stay a mess until next spring, there's enough room for the car anyway! I caught up with rb26dett by PM the other day, should be all set now. Going to get a few people some parts before vacation.
So.. Looks like I pretty much screwed my speedo and tach gears. Long story short, I had it all assembled and tested then noticed that the plexiglass was coming in contact with my needles so I had to pull the needles to shorten them a bit and in doing so, I completely pulled the metal pin out of the gear. I tried to fix it numerous ways (Including this: http://www.lotustalk.com/forums/f129/speedo-needle-fix-233593/) and I don't think its gonna happen.
Anyone know where I can purchase replacement gear housing? Figure it would be easier for me to just solder in new ones to the board.
EDIT: Looks like I'm getting closer to answering my own question but I figure I should update here incase for anyone's future reference... According to this forum post X15.166=XC5.166=X25.166: No Dom, rear contacts, no mounting pegs, internal stop, standard indicator shaft. Also, X27.168 can be used with some minor modification by cutting the mounting pegs.
I wasn't able to easily find the X25-166 motors, so I use x27-168 and just cut the rear mounting posts off.. Functionally they appear to be the same and they're easily available on eBay for cheap. Just be very careful when de-soldering the motor from the board - there are traces on the front side (under the motor) and if solder sticks while pulling the motor, it's real easy to pull a trace off the board. Make sure they wiggle freely after removing the solder, and you should be OK.
Awesome! Thanks for the tip! I ended up ordering these as they had good reviews and I could get it here tomorrow with Prime shipping. Looks like they are direct X15.168 replacements so I'll just do the same and cut off the rear mounting posts.
Does anyone have a copy of the pdf for the LED ring install? The link in the first post is no longer working and would love to put this back in the car today.
Thanks!!
141 - 160 of 187 Posts
