1 - 9 of 9 Posts
I need a little help..
If you order the base car...lets say with the LSS does it come with Firewall insulation or does that ONLY get added with the touring package???
When I am sitting in grid in a 90 degree day with the AC on waiting to make my run I don't want the car to get heat soaked from the lack on insulation.
I heard a rumor that the only way to get insulation was to get the touring package??? Is this true??? I thought you got MORE insulation with the touring package but the base car actually had some.
Someone please clear this up...thanks
I'm really suprised I haven't seen real weight numbers (standard vs. touring) yet. I've seen estimation and speculation, but no real numbers other than "1975 lbs. with the touring package". Have these numbers been posted, and I've just missed them?
Touring package adds 15 pounds total.
I read 12, but either way, not much. I was also under the impression that the tour package insulation is aimed at sound deadening, not cooling.
Steve
I asked about this at the LA auto show, and according to Nick Adams (Lotus Engineer), the weight is "about 15 pounds". If they are still fiddling with bits of the interior, 12-15 sounds like a reasonable range; I don't know how they'd be able to provide a spec to the nearest gram if things are still jiggling around a bit.
As far as insulation, he noted that the aluminum chassis is very good at conducting heat from the engine, and that the touring package insulation makes the car MUCH more comfortable temperature wise- the extra insulation (both in the top and in the carpets & firewall) is definitely directed at both noise AND temperature.
For what it's worth...
-Knute
1 - 9 of 9 Posts
