1 - 4 of 4 Posts
At the track day on Wednesday their was a vendor their selling custom race cars with the Ford 2.3 Ecoboost out of the Ford Mustang. These were serious full slick race cars. I asked about oil control /dry sump for sustained high G loads. Turns out Mountune a race/rally ford specialist makes an internal/partial dry sump for the Ecoboost motors. It looks like a factory system! The pump is internal so leaves the exterior for accessories
The motor - might slip right in to my Esprit....started wondering, so I checked out the Kennedy Engineering website - they make adapters for transmissions to all different motors.
Sure enough - they can do an adapter for a Porsche Boxster transmission to the 2.3 Ecoboost motor.
I dont know a lot about the Ecoboost motors but they are cheap and plentiful and 310 HP factory in the Mustang. Probably pretty easy and reliable 375 hp. A bit more reading, apparently they are cranking 800 - 1000 hp out of these motors for drag racing. Lots of snide comments out there about the 2.0 version?? Not sure what the issue is.
Might be a relatively easy to install/strong/reliable package in the Esprit and with the $2K Mountoune Drysump worthy of heavy track duty.
I think you could do the whole swap for less than $10k maybe a bit more with the dry sump if you could do a lot of the work yourself. hmmm
2017 Lotus Evora 400 manual, 2009 Rossion Q1, 2019 Jeep Cherokee Trailhawk
Track version of the Rossion has it. Rear clam is pretty low.
1 - 4 of 4 Posts
