So, my 88' Esprit has been running rather crappy. Getting worse gradually got me into the garage and in the trouble shooting mind set. As I have a number of spares, I used this as a "test" to confirm spares were good... but that is the longer version.
The short version is that the frequency valve was not operating correctly. So, popped in the spare. No change...
Changed out the lambda sensor. No change...
Blue based RPM relay swapped. No change. Hmmm...
Swapped out the ECU (known working spare). No change.
And so it was that I unplugged the WUR (the electrical connector). Problem instantly corrected!
Odd I thought... 2 yellow wires. One black wire... I assume this is the ground even though the wire diagrams all show the ground to be within the WUR. At any rate, yellow wires - one brings in electrical current and the other takes that current off to the Auxiliary Air Valve. As this 'connection' to the AUX Air Valve does not run through the bi-metallic strip, but rather connects at the blade terminal... the AUX Air Valve would be unaffected.
Now, unplugged I can only assume that the bi-metallic strip will not "warm up fast" and that is about it. The natural heat sink should eventually allow the WUR to correctly function...
But the thought I have is that the ground has indeed somehow failed in the WUR and that this created some sort of feed back into the frequency valve and thus cause the frequency valve to operate incorrectly (intermittent, weak, and not at all). Anyway... if the WUR is plugged in the frequency valve fails. Unplug the WUR and the car runs like a top once warm. WTH??? The wire diagram in no way seems to account for this.
Anyone have a different thought?
Thanks,
Cameron
Thanks,
Cameron
