1 - 6 of 6 Posts
Last night the 2012 IPS did not go all the way into Park when I shut if off. This morning it was all locked up with the Gear telltale. It went into forced Neutral and would not let me shut off the ignition. I pushed and rocked it but no change. I had to disconnect the battery to get it to reset. Then I was able to start it in Neutral. The gearbox would then cycle between R, D, N and Park.
I got these fault codes:
P172A, P1910, P1925
Here is why the ignition couldn't be turned off (from the Transmission section FA of the Service notes):
Fa.6 - Ignition switch and battery - battery disconnection Ignition Switch
The Auto ignition switch incorporates solenoid, which, when energised prevents the switch being returned to the fully off position. As the ignition is turned off, the TCU via pin 73 grounds the key interlock solenoid within the ignition lock. This physically prevents the key barrel being turned back to the fully off position to remove the key.
Once P – Park has been selected from the PRND selector console and the transmission is in park the TCU will de-energise the key interlock solenoid & allow the key to be turned to the fully off position of the lock travel and the key can be withdrawn from the lock barrel.
As the vehicle has Auto Park the transmission will (provided vehicle is stationary) go straight into park when the ignition is turned off, making the interlock system hard to notice as the vehicle will have gone into park before the driver can get to the key removal stage.
However if the driver attempts to remove the key while the vehicle is still moving then the TCU would activate the key interlock solenoid, thereby preventing key removal until the vehicle was stationary and in park.
Disconnecting the Battery
The transmission will default to P- Park rendering the vehicle immobile if the battery is disconnected or becomes discharged.
So, now she's in learn mode for the TCU (shift lights flashing side to side etc.) and I have to teach her how to shift again...... BUT, I can't seem to find the official TCU adaptive shift relearn procedure.
Discussion Starter #2
TCU Fault Codes DTC - Evora IPS Transmission
TCU fault codes - posting for reference to aid in future searches:
DIAGNOSTIC TROUBLE CODE (DTC) LIST
DTC TC Fault description Page
P0218 Transmission Fluid Over Temperature Condition 29
P0500 Vehicle Speed Sensor "A" 29
P0562 System Voltage Low 30
P0563 System Voltage High 30
P0601 Internal Control Module Memory Check Sum Error 30
P060A Internal Control Module Monitoring Processor Performance 30
P0610 Control Module Vehicle Options Error 31
P0613 TCM Processor 31
P0705 Transmission Range Sensor "A" Circuit (PRNDL Input) 31
P0710 Transmission Fluid Temperature Sensor "A" Circuit 31
P0712 Transmission Fluid Temperature Sensor "A" Circuit Low 32
P0713 Transmission Fluid Temperature Sensor "A" Circuit High 33
P0717 Input / Turbine Speed Sensor "A" Circuit No Signal 33
P0718 Input / Turbine Speed Sensor "A" Circuit Intermittent 33
P0719 Brake Switch "B" Circuit Low 34
P0721 Output Speed Sensor Circuit Range / Performance 34
P0722 Output Speed Sensor Circuit No Signal 34
P0723 Output Speed Sensor Circuit Intermittent 34
P0724 Brake Switch "B" Circuit High 34
P0741 Torque Converter Clutch Circuit Performance or Stuck Off 36
P0746 Pressure Control Solenoid "A" Performance or Stuck Off (SLT) 37
P0748 Pressure Control Solenoid "A" Electrical 38
P0751 Shift Solenoid "A" Performance or Stuck Off 38
P0753 Shift Solenoid "A" Electrical 41
Continued.....
ESC/ESC OFF CRUISE Updated 7th February 2014
Page 28
Lotus Service Notes Section FA
P0756 Shift Solenoid "B" Performance or Stuck Off 39
P0758 Shift Solenoid "B" Electrical 41
P0761 Shift Solenoid "C" Performance or Stuck Off 40
P0763 Shift Solenoid "C" Electrical 41
P0766 Shift Solenoid "D" Performance or Stuck Off 40
P0768 Shift Solenoid "D" Electrical 41
P0812 Reverse Input Circuit 41
P0813 Reverse Output Circuit 42
P081C Park Input Circuit 41
P081D Neutral Input Circuit 41
P0842 Transmission Fluid Pressure Sensor/Switch "A" Circuit Low 42
P0843 Transmission Fluid Pressure Sensor/Switch "A" Circuit High 43
P0847 Transmission Fluid Pressure Sensor/Switch "B" Circuit Low 43
P0848 Transmission Fluid Pressure Sensor/Switch "B" Circuit High 44
P0853 Drive Switch Input Circuit 41
P0872 Transmission Fluid Pressure Sensor/Switch "C" Circuit Low 43
P0873 Transmission Fluid Pressure Sensor/Switch "C" Circuit High 45
P0886 TCM Power Relay Control Circuit Low 45
P1613 Forced Mechanical Limphome Position 46
P1657 Ignition Key Lock Solenoid Control Circuit 46
P172A Forced Gear Neutral 47
P1780 Safety Processor: Neutral select failed 47
P1801 Park Position Feedback Switch Circuit Low 47
P1802 Park Position Feedback Switch Circuit High 47
P1803 Reverse Position Feedback Switch Circuit Low 48
P1804 Reverse Position Feedback Switch Circuit High 48
P1805 Neutral Position Feedback Switch Circuit Low 48
P1806 Neutral Position Feedback Switch Circuit High 48
P1807 Drive Position Feedback Switch Circuit Low 49
P1808 Drive Position Feedback Switch Circuit High 49
P185A Safety Processor Communications Fault: Safety to Main direction 49
P1860 Safety Processor Communications Fault: Main to Safety direction 49
P1904 Park Position Select Error – Incorrect feedback switch 50
P1905 Reverse Position Select Error – Incorrect feedback switch 50
P1906 Neutral Position Select Error – Incorrect feedback switch 50
P1907 Drive Position Select Error – Incorrect feedback switch 50
P1909 Transmission Range Selector Position Control Error 50
P1910 Transmission Range Selector Motor Driver 50
P1911 Transmission Range Selector Excessive Lost Motion 50
P1912 Transmission Range Selector Motor Circuit Low 50
P1913 Transmission Range Selector Motor Circuit High 50
P1921 Safety Processor: Incorrect selection of Drive 52
P1925 Safety Processor: Incorrect selection of Reverse 52
P1929 Transmission Range Selector Solenoid Performance 50
P1930 Transmission Range Selector Solenoid Control Circuit Low 53
P1931 Transmission Range Selector Solenoid Control Circuit High 53
P2757 Torque Converter Clutch Pressure Control Solenoid Control Circuit Performance or Stuck Off 54
P2759 Torque Converter Clutch Pressure Control Solenoid Control Circuit Electrical 54
P2769 Torque Converter Clutch Circuit Low 55
P2770 Torque Converter Clutch Circuit High 55
P2800 Transmission Range Sensor "B" Circuit (PRNDL Input) 56
P2805 Transmission Range Sensor "A"/"B" Correlation 57
U0100 Lost Communication with ECM/PCM “A” 57
U0122 Lost Communication with Vehicle Dynamics Control Module 57
U0123 Lost Communication with Yaw Rate Sensor Module 57
U0126 Lost Communication with Steering Angle Sensor Module 58
U0155 Lost Communication with Instrument Panel Cluster (IPC) Control Module 58
U0301 Software Incompatibility with ECM/PCM “A” 59
U0401 Invalid Data Received from ECM/PCM “A” 59
U0513 Invalid Data Received from Yaw Rate Sensor Module 59
Evora IPS Service Notes - Section FA Transmission
Here are the Service Notes (att) for 2014 IPS Transmission
If anyone has the official TCU adaptive shift relearn procedure please post it!!
Evora Transmission re-learn procedure
I did this re-learn procedure (below) that secretsquirrel posted on the way home from work. It finished and all shift lights are now off (procedure complete) and the Gear telltale with exclamation point went away. Scan shows no codes now. All is well again.
Here's the procedure. I bolded the key actions/points.
"You need to start out in sport mode, manual. Start going until you hit 4th gear. The lights will tell you less torque or more torque. Do not give it more than 20% throttle. You want the light to stay in the middle. If the left light turns on, less torque. If the right light turns on, more torque. If the middle light is on, keep it there.
Once 4th gear is done, all lights will come back on and the right light will blink. This is telling you it now wants 5th gear, so shift up one and follow the above process again. It will do the same thing and then ask for 6th gear. Once you've done 4,5,6.. all lights will go out. I ended up needing a highway for 5th and 6th gear, as I was doing over 60mph to do the re-learns in those gears. I didn't want a ticket going down side streets!
You now need to run the car through ALL the gears in non-sport mode, automatic (not manual). You need to run from 1-6 and 6-1, with no more than 20% throttle, for 15 minutes. This helps it calculate the fluid dynamics of the tranny. When you do the 6-1, slow down gradually. Do not do "blip" shifts, as it will not learn if it does a blip shift (basically quick deceleration). This is called the "Green Learn".
Once you are done with your 15 minutes of up and down shifts in automatic mode, you now need to drive the car on the highway at 70mph for a minimum of 20 seconds. After 20 seconds, slow down to a speed of 50mph, then speed up to 70mph again. Again, hold it for 20 seconds minimum. You need to do this 3 times.
1 - 6 of 6 Posts
