1 - 13 of 13 Posts
I haven't any driven any other car besides mine, just drove it home yesterday.
When in gear, the shifter can be moved left or right maybe 1" or so.
Thanks,
Yeah, some shifter play is normal for these cars as they come stock. There’s a few mods you can do to help decrease it.
Reactions: Darren Donovan
Unfortunately, the answer is yes. I can't remember if it's an inch but probably close to it. As the previous poster mentioned, there have been mods like the Alitech(altho discontinued) and ShiftR111. A quick google search will bring lots of info on it. And Congrats on the purchase as well.
I'll definitely do some research into the possible mods to tighten it up a bit. What a blast this car is.
Thanks!
see #5
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
I thought that was for looks only. Perhaps you should point out the advantages in your thread.
San
Thanks for linking to the thread San!
I thought I'd mentioned it in the first post there, but perhaps not prominently enough :) Greg & I will have to come up with marketing for it.
The gates are 0.6'' wide, and the rod is .5'', the tight tolerances eliminate most of the side to side slop. It's probably not going to feel anywhere as good as a proper shifter mod, but I at least feel like it helps with the shift action.
Less is Better
https://www.inokinetic.com/lotus/re-...y=Transmission
Question, do these work together.
Or is it one or the other?
Please, thanks!
Both can be done. There are threads on the subject. But I believe the play that the OP is talking about is the build up of slop in the transmission, cables, joints, and shifter.
1 - 13 of 13 Posts
