1 - 5 of 5 Posts
2013 Lotus Evora S engine replacement will any standard 2GRFE work to swap old engine?
2013 Lotus Evora S IPS needs engine replacement, supercharger and other ancillaries are fine;
will any 2GRFE work? or is it specific model years of the 2GRFE,
do I only need swap or provide larger injectors?
assuming the Evora has larger ones or are there ANY other spec differences or deviations from Toyo 2GRFE.
Please only respond if you have worked an engine swap or rebuild and know for a fact if its a simple swap or otherwise.
If there is a document that outlines any differences between the toyo 2grfe and the Lotus 2grfe , send me the link.
From what I have read, the answer is no. :frown2:
Supporting Vendor
The engine repair manual Lotus gives us is from a 2007 RAV4. I dont know much beyond that, sorry. Hope this helps.
Thanks,
T.J.
1 - 5 of 5 Posts
