1 - 10 of 10 Posts
I've been researching options to make my car safer on the track, but it's not a dedicated track car, I daily drive this thing, so I'm trying not to compromise streetability all that much. I'm retrofitting the Lotus stock harness bar (thanks RoadDad for the parts list!), but now comes the question of seats and harnesses. From what I understand of physics, when a harness stops me in a collision my torso stops way fast, so my head will want to come off. Ideally, I'd like to prevent that :D, but it appears that the Scroth 4-pt ASM is incompatible with HANS devices, 3-pt + helmet is probably safer, but I need more support since I'm flopping around in the seat in turns. So, is anyone aware of any ASM harness compatible HANS devices? I'll run 5 or 6pt harnesses if I have to, but I imagine I'll get annoyed sitting on buckle pieces and I don't like the notion of butchering my seats.
Hmm, interesting, thank you. I had seen the sticker on the Scroth harnesses which said they weren't compatible, and I just assumed that was true for all of them.
I would highly recommend that you check out the R3 device from Safety Solutions.
Safety Solutions - Racing Seatbelts| Safety Restraint | Auto Harness
It is SFI certified and it does not require a harness to work correctly. It will even work in a car with stock seat belts. No affiliation, just a happy user. They make a removable pad that you stick in the seat and then sit back against it. I use mine in my F600 road racing, but I have used it once or twice in my Elise at the track.
+1 on being a happy R3 user. I will point out that there is a 1.5" inch thick spine on the R3 that goes half way down your back. as the previous poster mentioned, there is a pad that makes it more comfortable. However, it pushes you forward, so it will make your stock seats less supportive.
Mark
Very surprising. HANS requires the shoulder harness to remain taut. The ASM belt has a "breakaway" on one of the shoulder belts, rendering the HANS nonfunctional. I wonder how they are getting away with this.
Indeed, I double checked on the Schroth product webpage for the profi ii ASM (Schroth Racing Harnesses) and they backup the release from HMS:
You can add a single or dual sub strap to make this belt into a 5 point or 6 point at any time. We have recently tested this harness with a HANS device, and the results were great. You can use 4 point ASM Harnesses with a HANS device.​
:shrug:
-chris
I have an R3 as well and it's OK. I get a bit of redness/chafing from the chest strap.
The pad is only really necessary, IMO, if you tend to bend your head forward. If I keep my head aligned with your spine (back of helmet firmly against seat), the thickness of the R3 doesn't bother me.
If you're going to be setting up belts for a HANS device, I suggest you read the FIA guide in this link
http://argent.fia.com/web/fia-public.nsf/D05EDB3E8EF2FB81C12573150041C255/$FILE/Guide_HANS_2007.pdf
HMS aka Joe Marko gave me the green light on my HANS with that harness till its time to replace. Is it a perfect solution? No! Is it better than 3 point belts or 4 point with no HANS? Evidently so! Testing of HANS under differing conditions keeps pointing to the same fact. The HANS works and protects that vital part of your body. The neck. :huh: I know a few guys here got on their soapbox on me a few months back, but if you are formally racing yea you should have 6points, racing seats with custom engineered mounting, harness placement, etc. In a perfect world where everything was free, we'd all do that. For those of us that do some HPDE days, etc, as we start pushing the envelope more, it is wise for us to enhance our safety equipment. I feel more secure and safe with my HANS than without. When I replace my belts, ?next year, I will go 5-6 point, but for now, it is an incremental improvement. I find it hard to believe you are safer without a HANS than with one as long as the belts are securely placed over the lip of the shoulder frame!:mad:
BTW, seen as I am in a street car, if it really hits the fan, I still have the airbag also!! next thing I'll hear is that also dangerous and it should be disconnected??:wallbang:
BTW notice the year of that FIA guide 2007??
1 - 10 of 10 Posts
