1 - 9 of 9 Posts
2011 Lotus Evora
My 2011 Evora has a single exhaust pipe. Could this be a factory option or is it aftermarket? Most of the pictures I’ve seen of other Evora have been dual pipes but I’ve seen some single exhaust pipes too. I couldn’t find anything with a search.
Aftermarket. Loud?? Bet its a Plack
2011 Lotus Evora
I‘ve only driven another Evora NA one other time (before I bought this car) so don’t have anything really to compare it one. Doesn’t seem too loud although sounds good at high rpm.
That doesn't look like a Plack, as there would be no muffler behind it. The oval outlet looks slightly off-kilter; wasn't there a particular exhaust like that a while back?
Yep, that's the Larini exhaust. Have the same one on my car along with the secondary cat delete pipe.
1265860
2011 Lotus Evora
Discussion Starter · #8 ·
Thanks. Glad to hear it has an upgraded exhaust as I had read that is one of the first recommended modifications. I also didn't have any complaints with the sound of the engine as often discussed here so the better exhaust must be why.
Illegal Alien
The slight off kilter exhaust supplier is Larini. As others have noted that tip style is Larini. Larini saves a good 15 lbs plus from stock, has a durable SS that seems to stand up for at least 5 yrs and counting. I like the tone on the Series 1 cars and found it a perfect muffler in combination with headers installed.
I include a like listing a number of exhaust options and their weights. Note S1 cars use a different exhaust diameter than S2 cars (4xx models), they are not interchangeable without custom adapters.
1 - 9 of 9 Posts
