1 - 8 of 8 Posts
Gamera The Atomic Turtle
my pic....
here goes nuthin.... dry pressure test ok....thanks
shay2nak
is there a way to check the level?
This board has hit a new low, Lotus owners posting pics of their nipple.
atleast it wasn't pierced - i won't date a girl i can't get through a metal detector....
Clutch bleed is done!!! I did the trick of refilling the resevoir w/clean, virgin fluid after using the baster to suck out the old junk - cut down on bottle refilling. Used about 3/.4 big bottle so far...
Onto the brakes...then the tricky job - uncap my oem oil lines (phil capped during oil copoler relo), clean out connectors as best i can to make oil free, mix jbweld and apply to caps for a hopefully no oil leaking (just a drip) from the old lines coolers. It's making the under tray and the oil pan yucky. That should hold me until i pull all that stuff this winter...
brakes are done..about 3 1/2 hours, first time through. I was being careful, going slow.
1 - 8 of 8 Posts
