1 - 9 of 9 Posts
Hi, I have recently had someone install a Moroso oil pan for me. Yesterday when I was changing engine oil I noticed a gear next to the oil pan is exposed in plain sight (see attached picture)
Given the underside of the car is covered, it probably is ok, but I am not sure if the car came from the factory like this. Any ideas?
Thanks.
There is a black plastic cover on my car there. It fell off once and I put it back on. I think it was just a snap in piece. I am not sure if it fits with an aftermarket pan.
As i recall a small cover goes there, mainly to keep rocks and dust away from the clutch. Probably not a big deal.
The cover will not fit back on with the Moroso pan.. No big deal.
Thanks for the prompt replies. Given that it falls off eventually I guess I'm good. Good to save some weight anyways.;)
+1
what he said........I have the same oil pan with the same exposed gear, I should say flywheel.........had it like that for about 2 years and no issues/no worries
Same thing happened to me before.
Lotus tech found the cover was missing and
fixed it without charge.
1 - 9 of 9 Posts
