1 - 20 of 43 Posts
I've read a number of how to's regarding putting the elise on stands, so I know how to do it, but I was wondering if anyone had any recommendations on specific jacks and jack stands that work best with the elise. I should be getting my car within the next few months and want to have some of the basic tools like jack/stands, torque wrench etc before I take delivery. Any suggestions would be much appreciated!
Couple threads on this.
FIFW, check out Harbour Freight.
I really like my screw jacks as they give you pretty-much infinite adjustments. I don't remember where I got mine, but they are similar to these.
I bought the "nicest" Harbor Freight aluminum racing jack, $134 I think, works pretty darn well so far, goes up slow enough and can lower well controlled. There is a smaller cheaper one but universal joint on the valve control was really crappy, looked good for <10 uses. For my occasional use I think this will be fine, I jacked the car up to put it on the ramps for an oil change last night. I don't really like the risk factor of backing onto the ramps and slipping the clutch a bit. Lifted one side, suck a 4x4 under the rear wheel, lifted the other side onto the ramp then lifted the 4x4 side onto the ramp, worked great, low risk, my ramps are only 6 or 7 inches high. Make sure you point the ramps in the right direction or you will be disappointed when you are done and drive it off.:eek: And no, I didn't do that....
Jim
For jackstands, a lot of us use Torin "Big Red" jack stands. They are aluminum "posts" with a fairly wide base. The advantage of them is that the tops are almost flat to support the flat support points under the Elise. Optionally, it's easy to place hockey pucks on the tops to make a padded top. At least one person drilled nd tapped the top of the jack, and installed a counter sunk bolt into the hockey puck. I just carved out some notches in the bottom of the pucks to fit the small tabs on the top of the jack stand. You can get them on-line, or at Pep-Boys, etc.
The shop that works on my car said they went thru 4 craftsman jacks in the past and and they all broke pre-maturely and Sears won't honor the Craftsman warranty.
Big reds :up:
Look like they were made for the Elise.
Car sits nice and level, even when using the chassis beam under the rear shear panel, so the rear stands are a little more extended.
Bye, Arno.
I'm using a Matco 3 1/2 ton jack (MFJ35A) ... it has a big articulated rubber puck built right in, and can get under the car easily even when the other side is up on stands.
EDIT: Second photo shows the puck under the car... there's about an inch of clearance... my car is stock ride height.
Discussion Starter #11
Big reds :up:
Bye, Arno.
This seems like what im looking for... do you have a part # or a link? Thanks!
Discussion Starter #12
Thanks, this is probably what I'll go with... either this or the speed deamon (MFJ214) since the elise doesn't really come close to 3 1/2 tons rotfl
Puff Daddy
Big Red's FTW! If you have an Elise then you need those stands TADTS
I use a Craftsman low profile "racing" jack. It has a rubber pad built into the large lifting surface :)
Discussion Starter #17
looks like ill have to go w/ the big reds :up:
and, excuse my ignorance... but ive been on forums for years and still don't know what FTW means. i saw someone with a tattoo a few years ago that said FTW and he told me it stood for "f*ck the world" :shrug:
I didn't know either. Just Googled it and got:
Well, this peculiar acronym expression stands for "For the Win". It is an expression of enthusiasm. "FTW" is the same as saying "this is the best" or "this item makes a big difference, I recommend using it". Examples would include: "anti-lock braking, ftw!", "spellchecker, ftw!", and "low-carb diets, ftw!"
This FTW expression, like many other internet expressions, is part of online conversation culture. If you want to know more, here are 322 other common Internet expressions explained...More Internet for Beginners Q&A
I have the cheaper HF aluminum jack and it has been bulletproof over four years of frequent use.
For jack stands, I have a set of super-cheap, generic auto store stands with the racheting posts. I threw away the posts and use a hockey puck directly on top of the base. Works well and turns out to be the perfect height.
My local AutoZone had blue aluminum equivalents to the "Big Reds" ... Some used hockey pucks from a local rink and my car stands in style ... :cool:
1 - 20 of 43 Posts
