Hey guys!
Attempting to jack the car up so I can remove the tires.
Thanks!
in that 1st picture 'Y' is actually fine to use for a rear a jackstand point (or jack point on a 4-post lift), however you will bend that aluminum shelf if you don't support that pocket above it since its pretty thin (you can actually see that had been used as a stand point before)
although a lift kit exists for that specific spot so you can use a 4-post without needing to remove panels to access 'C' & 'D'
MWR Lift Point Kit
otherwise 'B' & 'A' are the only accessible jack points without removing panels, but 'A' is not a preferred spot for rear jackstands (thus where 'C' & 'D' come into play)
'C' is located under the service panel that would need to be removed (where the naca ducts are)
& 'D' is located under the diffuser (however there is also a helper bar that can be used to jack the whole rear up without removing the diffuser, utilizing bolts located at 'D')
http://www.lotustalk.com/forums/f95/jack-helper-184682/
TLDR; 2 products are available for lifting convenience... & 'A'/'B' are the only lift points accessible without removing panels
