1 - 11 of 11 Posts
Hi all. I recently picked up a 2005 Lotus Elise in great condition... except for the fact that it has a blown engine! Luckily the price was right.
Do you know if a cheap, low mileage JDM 2zz-ge engine on eBay will work just fine for a replacement engine? I did about an hour of searching to see if I could find an answer, but I didn't have any luck getting a definite "Yes, it will work just fine" answer. I know sometimes sensors and the locations of some things vary depending on whether the engine is JDM or USDM.
I do live in a Texas county with emissions testing, for what it's worth. So I'd need all of the emissions stuff and ports to be there. I know in Japan they have more lax emissions standards, so they don't always have the same stuff on their engines or in their cars as we do.
Thanks in advance!
Assuming you have possession of said blown engine, just swap all the emissions parts over to the new one.
Thanks. We have the engine still and all the emissions parts thankfully. I guess I was more wondering if there would be places to put all the emissions parts on. For example, maybe there aren't some ports or holes for emissions related sensors or vent systems on the JDM engines?
The main one I know of (so someone else, speak up if I am missing anything) is the exhaust porting, but the Elise header comes with a plug for that since it is not used on our platform.
Yes 100% you can move everything over from a JDM engine. You can get them locally from JDM king in Houston, or ebay, or LKQ.
You are in for lots of fun.
These are brilliant cars.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
My opinion on 'used' engines
Nobody cares
LKQ, JDM will send you an engine with a hole in the pan
If you 'know a guy' IOW have a friend who is a mechanic that has a relationship with an engine supplier, like LKQ. It is your only hope of getting things worked out in your favor when the engine they send you is crap
Do not assume that because they rinsed the engine down with shiny black stuff, that it is any good
Discussion Starter · #9 ·
exigegus, I appreciate the honesty. I've had good luck with replacement engines from ebay with other cars I've had, but those are more one-off engines with more records (e.g., an S2000 engine), and not a dime a dozen 2zz's that are "JDM, with an estimated mileage of 50k on the clock... but we don't actually know the exact mileage".
I've thought about just spending the money and getting an engine from MWR. However, I was put off by the fact that when I called them earlier today the person I talked to really couldn't tell me anything about the engines they were selling. That, and after all the fees + shipping, an engine from them was going to be like $800 more than what it looked like eBay engines were going for after all the fees + shipping.
Maybe a MWR engine is still the way to go, but I was pretty put off by the call. I don't think I learned anything from it, or anything about what my $2.5k (after all costs) was going to buy me. Honestly, it didn't even sound like they wanted to talk to me. Their phone menu system was constantly "Look at the website for all your questions!" and "Are you sure you haven't already found the answer to your question on our website?" throughout, and when I did finally get a hold of someone, the call was kept very short.
As a contrast, I also called BOE to talk to them about some of the stuff they sell. I spoke to Andrew. What a guy! I think he talked to me for like an hour or more tell me everything about the car, what could be done, what the pros and cons were of the different things, etc. If they had an engine in stock (I should have asked... there wasn't anything listed on their website), I would have bought one then and there. They will definitely be my go-to place to get Elise stuff going forward.
If the labor is worthless to you like it is to me ;) just buy a $800 engine from Houston. If you are paying someone to install it get the 2.5k engine.
Actually now that I type that a FB friend had a MWR engine come bad. So **** that just buy the $800 engine from a JDM shop. Don't get it from ebay. Shipping in TX is $100 and 1 day.
Discussion Starter · #11 ·
Thanks for the thoughts!
Any recommendations on JDM shops? I see LKQ has a 2ZZ-GE in stock from a Celica GTS, but they will only ship to a commercial building. It is going to a friend who is basically a master mechanic up in Dallas to do the work, but he is doing it in his garage.
1 - 11 of 11 Posts
