1 - 14 of 14 Posts
Just bought this car and was wondering if anybody has any history on it? Based on everything done to it I have a feeling someone in here knows something about it so I thought I would ask. I bought it in NY where it looks like it was purchased in 2018. It has a full cage. Parking brake is missing. Seems to be a lot of interior missing from when the cage was put in. It has an aftermarket supercharger on it. Has the lines ran for a fire extinguisher kit. It was definitely tracked.
Just looking for any information to kind of track down the story.
On a side note the amount of neighbors that stopped by to see it has been crazy. These cars are definitely attention grabbers. I'm pretty excited to be stepping into a lotus.
Sent from my Pixel 5 using Tapatalk
Sorry, no. But looks good.
Sounds like this “excuse me”….
Get something such as a Stebel Nautilus. Or, from beloved parts supplier, RD Enterprises: Compact Air Horn $59
Ultra Compact two-tone air horn unit measures about 4-3/8" tall x 5" long x 3" wide and weighs under 2 lbs., and it's LOUD! The sound measured at 2 meters is 115 dB. Easy installation because there's only one part to install, horn compressor relay and instructions included.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s and InoKinetic’s for two examples.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
18. Many benefits to joining Lotus Ltd (USA Lotus club). Get help wherever you are, using the contact booklet they update every year. (I’ve helped a few ppl who contacted me.) This is who stages LOGs (Lotus Owner Gatherings) every year. https://lotusltd.com
Plus, “How to bleed brakes”:
Maintenance and Repairs.
How to Search:
no space between site: lotustalk.com
Administrator
You can try VIN search and do some detective work based on PO info that you may have.
2006 Exige
Good luck with your new car. I have the same car so if you have questions about how it came from the factory PM me. I turned mine into a track car.I’m not familiar with your particular car but I know what gets changed for tracking.
Thanks! It looks like the guy I bought it from has neglected it the past year or so so I need to just go through the car and check it over. Eventually I'd like to remove the cage and return the interior to stock. It looks like the cage was bolted in. A lot of the interior plastics have been cut up. Other than that, is it as easy just removing the cage or are other modifications usually made to the car to fit a cage?
I hope to have some time this weekend to really see what was done but if you have experience with the cage installation I figured I'd ask. Thanks!
I used to see a black 06 with a Mohawk roof (as you know the 06's didn't have Mohawks, and the roof bump it did have was not functional) at cars and coffees in Maryland a few years back. As far back as 2014. A very young guy had it at the time. It might have migrated North.
I have heard that driving a caged car without a helmet requires caution, especially if the airbag has been deleted. Others may have more knowledge or experience...
2006 Exige
Often the e-brake has been removed. It may have 21/2 degrees of camber or more so you may want to reshiim.1 deg or so if you’re only going to street it.
It may have racing brake pads which will wear rotors quickly on street driving.Check sandwich plate for the right type and thermostat.There is a current thread on this where exigis gave excellent advice.
2007 Phantom Black Exige S
Depends on the configuration and clearance of the cage, particularly where one's head might strike the bar(s). In that case, yes, it's a major safety issue.
What A track beast! If you need some sill covers I have some that I wrapped in leather for the interior. Just shoot me a pm.
I think it's this one.
Congrats on the new purchase. Lots to learn, invest some time reading up on these and common failure points and double check those.
If you're looking for recommendations change your fluids, particularly the oil and send it to Blackstone for analysis. Then do that for the next few changes. The results should be consistent(ish), there are indicators in that analysis.
Brakes: Track car likely has track pads.. Validate that, you don't want to be using those on street. If you can't tell get some cheap Hawks.
That cage is a concern with a lap belt. At a minimum, and it will only help for minor occurrences, put some padding on the bars by your head. A harness will fix the threat of the cage, but you risk internal decapitation without a helmet and Hans device.. Typically a cage is the line you only cross when going 0% street.
Put some black vinyl wrap on those front accessory covers.. just saying...
Reactions: Me!
Discussion Starter · #14 ·
Thanks! I've been going through a lot of old posts and have already learned a lot. And I agree with all the concern about driving with cage without wearing a helmet which is a big reason I'm taking it out. I'm picking up the stock rollbar on Monday and will be removing the cage next weekend.
And why black vinyl? Haha you don't like the carbon?
1 - 14 of 14 Posts
