1 - 20 of 32 Posts
Nice car. Good for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Stock: “Excuse me”
How to Search:
Great tips. Thanks a ton
Congrats!!!! Beautiful car. Enjoy and drive safe!
Oh man, I'm sure it's not intended that way, but this list has the effect of making me nervous about getting an Elise.
For example:
#4: how do I check to see if a certain car has had the oil line fittings recall done? Seller is not sure.
#6: wait at least 20 minutes before driving spiritedly. Even in hot weather? Regarding removing the 2 oil coolers, is that necessary (or highly recommended) for most cases? I live in an area where it gets hot in the summer, so the oil coolers should be kept, no? My area also gets down to the 40s in the winter, will it be necessary to remove them, then reinstall for the summer?
Thanks!
I believe that car used to be near me in Colorado. Very nice car.
Indeed. Jeremy’s. Good guy, was very honest about all the quirks and imperfections. Picked it up this last weekend.
For example:
#6: wait at least 20 minutes before driving spiritedly. Even in hot weather? Regarding removing the 2 oil coolers, is that necessary (or highly recommended) for most cases? I live in an area where it gets hot in the summer, so the oil coolers should be kept, no? My area also gets down to the 40s in the winter, will it be necessary to remove them, the reinstall for the summer?
Thanks!
#4: I called a Lotus dealer and gave them the VIN and they checked for me. That’s the easiest way I know to know if it’s been done.
#6: You could always install a bypass valve to easily enable or disable them. A lot of people just fab up block off plates and remove them for extreme summer or track use. But yeah, 15-20 min to ensure oil is up to temp to protect the high lift cam. If you have an oil temp sensor, you can know exactly when it should be ok.
Congrats. I'm starting my look for an Exige S. What was your final negotiated price? It seems like dealers are jacking prices. Where did you get it? Private party or dealer?
Thanks
Discussion Starter #13
Thanks
It was listed at $45k, but I was insistent on an Exige with a supercharger. Private party in Colorado. Drove it back to Texas.
Super nice! Congrats!
Thanks!
Loves to talk
#6: wait at least 20 minutes before driving spiritedly. Even in hot weather? ?
This is true for all vehicles to a lesser or greater extent. It takes longer for the mass of the motor and oil to reach optimal temperature than it does for the coolant.
shay2nak
congrats! more pics please!
^Never seen that wing... is just some add-on to the stock wing? Overall, your Exige looks amazing! (You win sir)
1 - 20 of 32 Posts
