1 - 6 of 6 Posts
I have a JVC KD-NX5000 and when I'm on the hard drive and fast forward the first song on Random the screen will freeze and no music will play. I can access the menu and maps but the music information disappears and no music is played. Even if I turn the car off and remove the key the screen stays and the only way I can get it to go away is to remove the face and reattached it.
I just installed the latest Firmware update yet it still happens.
You can hear music in this car?
Did you do the install, or did the dealer? My (haphazard) guess is that something is wrong with the wiring, which explains why you have to disconnect the entire unit to get it to reset.
Just a guess.
I had an audio shop do it, one of the best ones in Sac.
I don't think its the wiring cause the Hard drive is part of the unit. It use to do this before but the unit would just restart itself and then it'd be fixed until I turned the car off.
This happened with mine once when one of the files I had on the HDD became corrupt. These days I rarely ever use the HD, and instead just use an flash-based iPod.
It's a great unit, but I'm still leery of hard drives in cars.
1 - 6 of 6 Posts
