1:47.9 clockwise in 07 Exige with a lot more mods on RE71R tires.
Outside
HkFever side skirts
HkFever front spoiler
HkFever rear spoiler
Reverie CF side scoops
Sector111 rear diffuser " aluminDIFFUSER"
RLS/NCI allen conversion for undertray/diffuser
Lotus S240 MoHawk Roof
Inside
Alitech shifter
Reverie CF shift knob
Sector 111 shift cables
NRG Gen 2.5 quick disconnect
OMP steering wheel
Sector111 DBW pedals
Sector111 Sys 6-pack
Schroth ASM belts
Safecraft stainless steel fire system
Chassis
Nitron double adjustable coilovers
Sector111 Tasty Tool adjuster
Stainless steel brake lines / Motul 600 fluid
Sector111 DS brace rear toe links
Innovative Motor mounts. Front and rear.
Jack point lift kit
Wheels and tires
SJ Racing Leggero forged wheels looks like $1500-$1900 used
Toyo R888 tires 195/50R16 ft - 245/40R17 rear
Sector 111 Bullet stud kit
Engine compartment
Bone stock engine. Never installed bigger injectors, smaller pulley, etc.
Coldfire 270 ECU and stock ECU.
BOE surge tank
In tank fuel pump upgraded to Denso S260 pump. Sector111 Plug-N-Play Fuel Pump
Pump rated (280lb/hr vs 150lb/hr stock @ 47psi)
Radium catch cans, with dipsticks
RLS intercooler
RLS CF intercooler shield
RLS CF baffled intercooler shroud
RLS side intake kit
Radium silicone intercooler hoses and t-bolt clamps
Sector 111 GPan baffled oil pan
RLS/NCI oil lines
Factory Lotus Cup air box
Exhaust
2bular custom 7x18 GT3 exit exhaust
2bular High flow cat
2bular Catless U-Pipe
Battery
Odyssey 680 battery
Sector 111 Xtender battery cutoff switch
RLS/NCI Battery mount
C-Tek trickle charger
Misc
Lotus Sport floor mats
JVC 1.5 DIN head unit with back-up camera (KD-NX5000)
Hella horns
Sector 111 folding front tow hook
Sector 111 BBHook2 rear tow hook
My changes
Nov2018
949 Racing 6UL 111 wheels via Black Watch Racing
17x9 rear 15.8 lbs with Bridgestone RE-71R tires 255/40R17
15x8 front 12.6 lbs with Bridgestone RE-71R tires 205/50R-15
BF Goodrich Rival S 1.5 tires 225/45R-15
Dec2018
Penske double adjustable shocks from BWR 550F/800R springs
BWR front sway bar track version
Lowered car to 225 mm front 230 mm rear
Feb2019
V2 on front suspension arms
Car alignment 2.7 camber front
Changed alignment Camber 2.0 front, 2.3 rear
Shock settings front compression 10 rebound 12
Rear compression 22 rebound 2
Mar2019
Replaced OEM brake rotors with used Sector111 hatted rotors from Wire Wheel, had to replace the front rotor portions which I got from Inokinetic
G-LOC R8 Brake Pads front and rear
Jul2019
Bosch EV-14 Injectors 550cc
3” supercharger pulley and belt
BOE air intake
BOE Sport Cat U-Bend for 2ZZ DMC Header
DMC Ultimate 2ZZ Header
BOE tune
