1 - 9 of 9 Posts
If you've seen my other threads ever since I installed the Larini De-Cat pipe and Arqray exhaust my Exige S has had issues of stalling constantly at idle.
I took a look at the entire exhaust system and noticed that where the de-cat pipe goes into the car (those spring loaded screws), the pipe is slightly crooked. I know this needs to be fixed, but my question...did you have to use longer screws or modify anything to actually get that pipe to fit snugly? I had a hell of a time trying to just get those spring screws to engage the thread!
Thanks!
2008 Exige S240
cut the springs!
You must cut the springs using a dremel or something.
Cut off two coils per spring. Then tighten the spring bolts evenly to
ensure a good seal.:wave:
Awesome thanks!!! :nanner:
Any follow up on whether or not this was a solution? I'm having the exact same issues as you and I'm having a tough time finding a solution.
Just payed 60 bucks for a custom test pipe BTW....what are they still getting for the big name ones?
Whoa! Do not cut those springs. You are removing the flex out of the system and given the amount of engine movement, that's not a good idea.
I just did not seat the two screws completely, nearly 1/4 inch short, as best I can remember. It's been over a year and more than 3,000 miles with no problem. And yes, it is a Hell of a job getting those back in. The Larini simply does not fit, but can be made to work. Sure sounds good though. Then there is the CEL issue.......
The toyota screw from a Celica GTS are a little bit longer.
1 - 9 of 9 Posts
