1 - 3 of 3 Posts
I have on the way parts to replace the lower front portion of the doors with ones like later model which included hole for door speakers.
Anyone know what size speakers and max depth will work there?
i.e. goes in the space in the pic below.. Hoping to narrow down choices so when the door part arrives can already have speaker purchased...
Google was not my friend on this at all... :p
Thanks!
Cal H
The way that speaker fits is on the door itself, then the door/speaker card mounted over it. The actual part is an Alpine speaker 6 1/2 -'16cm DIN' Alpine-sub 6062GD. . The Lotus part # is A082M662SF not that you want to order it from Lotus. There is a matching tweeter that goes with it
Updated model closest to OEM.
Alpine SPR-60c 6 1/2" speaker system
Dimensions
Tweeter Mounting Diameter (mm): 37.9mm
Tweeter Mounting Diameter (in): 1-1/2''
Tweeter Mounting Depth (mm): 19 mm
Tweeter Mounting Depth (in): 3/4''
Woofer Diameter (mm): 165mm
Woofer Diameter (in): 6-1/2''
Woofer Mounting Diameter (mm): 136mm
Woofer Mounting Diameter (in): 5-3/8''
Woofer Mounting Depth (mm): 59mm
Woofer Mounting Depth (in): 2-3/8''
Crossover Size (mm): 63mm x 32mm x 24mm
Crossover Size (in): 2-1/2'' x 1-1/4'' x 15/16''
Thanks !
1 - 3 of 3 Posts
